REVIEW: Solid Motor Mounts.
Old Jan 7, 2008 | 11:43 AM
Grifter's Avatar
Originally Posted by 8a8mfh
In the same sense you cant use a solid trans mount without solid motor mounts, even with one bolt holding the trans to the cross member it can break the trans housing.
Seems risky that the torque arm is still trying to raise the trans up, I'd want a solid trans mount too. But thats just my theory.
I see what you're saying. I do have the relocated tq arm too.
Old Jan 7, 2008 | 12:17 PM
Grifter's Avatar
I am pretty sure the only thing that is still kind of hitting is the over the axle pipe contacting the upper panhard bar. I wonder if UMI's relocation kit would fix that, hrm...
Old Jan 7, 2008 | 04:03 PM
TheSilverOne's Avatar
i have a slight vibration at 600-800 rpms when in gear and i can feel the cam when on the highway. it's a reminder i'm driving a muscle car.
Old Jan 7, 2008 | 10:10 PM
white_ls1z28's Avatar
how much closer are the headers to the ground after you switch out the motor mounts
Old Jan 8, 2008 | 12:06 AM
Damian's Avatar
LSX Mechanic
Solid motor mounts make replacing a clutch a living hell.
Other than that they're nice
Old Jan 8, 2008 | 12:27 AM
2002_Z28_Six_Speed's Avatar
Originally Posted by SiL3NtXWS6
CONS: Have fun removing transmission !
+1
This comment takes the cake!
Old Jan 8, 2008 | 06:10 AM
Grifter's Avatar
I didn't notice any difference in ground clearance.
I do remember reading that. I guess I'll have to deal with that when I change my clutch.
Old Jan 8, 2008 | 11:21 AM
Coy's Avatar
Coy
I installed Spohn solid mounts in my last car (98 M6 TA), and when I need mounts for my new one I am going with Spohn solids. Easy install, and made the car fun to drive again.
Vibrations werent horrible, but you could feel them. I also used a 1LE trans mount. The prothane trans mount was over the top interior-wise. Made the door panels vibrate, lol.
Since I have an A4 this time I am going full solid (motor/trans) when I replace the mounts.
Old Jan 8, 2008 | 11:23 AM
Coy's Avatar
Coy
Actually it raised the driver side slightly when I installed them. I never checked to see how much ground clearance I gained, but I am sure it wasn't substantial.
Old Jan 8, 2008 | 11:28 AM
Grifter's Avatar
Yeah, same here. I mentioned it earlier in this thread. Nothing crazy like you said though.
Old Jan 20, 2008 | 11:16 AM
Grifter's Avatar
I'll have to cross that bridge when I come to it. But I would think that lowering th subframe should give me enough access to the top bellhousing bolts.
Old Jan 28, 2008 | 04:25 PM
  #32
Grifter's Avatar
Here's some under car pictures of the mounts. You can see how much room you have on the driverside.
Old Jun 26, 2009 | 01:13 AM
  #33
metalmechanic's Avatar
yep, kinda like this, my dash vibes a little in first
Attached Thumbnails REVIEW: Solid Motor Mounts.-10-30-08_1454.jpg   REVIEW: Solid Motor Mounts.-10-30-08_1455.jpg   REVIEW: Solid Motor Mounts.-10-30-08_1507.jpg   REVIEW: Solid Motor Mounts.-10-31-08_1627.jpg   REVIEW: Solid Motor Mounts.-10-22-08_0937.jpg
Old Jun 26, 2009 | 02:02 AM
  #34
LCplmarine98's Avatar
I am doing a H/C swap soon i think im going with the poly motor mounts.
Old Jun 26, 2009 | 02:42 AM
  #35
twelver12's Avatar
nothing wrong with some vibrations and noise these are muscle cars not luxury sedans
Old Jun 26, 2009 | 07:29 AM
  #36
Hardtop's Avatar
I put poly mounts in my car during the header install. There just a slight bit more vibration at idle, and I can't tell the difference at cruising speed. What is the advantage of solid mounts over poly? My car is a street car that I race occasionally. I've ridden in cars with solid mounts, and think most people would prefer poly mounts. I know it's a performance car, but I don't need engine vibrations to remind me of that, stepping down on the gas pedal does just fine.
Old Jun 26, 2009 | 07:57 AM
  #37
WS6TransAm01's Avatar
CARTEK Racing
dumb question; are there solid motor mounts that will work with a BMR K-member that has the motor mount brackets built in?
Old Jun 26, 2009 | 11:50 PM
  #38
Arc00TA's Avatar
I just put in my spohns today. It was pretty easy. I can't tell if I like them or not yet, my car feels like a massage chair.
Old Jun 27, 2009 | 09:53 AM
  #39
SiL3NtXWS6's Avatar
Not that I know of. I switched to poly when I put in my BMR kmember and didn't notice any difference anyway...
Old Aug 29, 2009 | 12:52 PM
  #40
Grifter's Avatar
Looking good! I still love mine! I don't even notice the vibrations anymore.
You can't go wrong with either one.
x1000000000.
Solid mounts are just that; solid. Poly mounts are great also. For a mostly street driven car I would suggest poly mounts. Like I stated in my first post I just like the slight weight savings and complete replacement of the mounts when running solids.
I do not believe so. I actually just posted in a BMR k-member thread in the suspension section. Spohn is the only company that I am aware of that makes it, I just don't see why the others wouldn't. Unless I'm missing something it's literally just a plate with holes in it to accept stock mount pedestals/solid mounts. I'm also surprise that besides Spohn(and I think Madman) no other company makes solid mounts. I talked to UMI before I bought my Spohn's and they said they were planning on it but that was awhile ago. I know it takes more to make these products than it seems but solid mounts for LSx guys seems like it should be a standard product in your lineup.
