Experience needed, Easy install??
Old Jan 1, 2008 | 10:58 PM
slowjoe99's Avatar
Question Experience needed, Easy install??
I plan on doing a cam swap with supporting mods and also an intake swap. I have LT headers. I also want to do heads at the same time. How hard is it to change heads without removing the engine? Anyone with experience got any tips?
Old Jan 1, 2008 | 11:46 PM
ssheets's Avatar
It took me and my brother a week, but we cleaned every thread and chased them with a tap. I've heard of guys doing it in 3 days...I think if you did a few you could make that timelinem, but first time I would plan a week. We also installed the longtubes and did a rear end swap.
It's a 1,000 minor details, but nothing really hard. Just take your time and follow the Howto. They're not perfect, but they sure are helpful. I think on the SS you can remove the cowl where the wipers are? The worst thing I ran into was the little sharp fasteners for the hood seal. They're like razorblades and slice your hands up when working under the cowl.
Old Jan 1, 2008 | 11:56 PM
socmguy's Avatar
Restricted User
Dude, that whole job shouldn't take more than a day. Even if you're taking your time. With two people it should be even faster. Just take your time and don't rush anything
Old Jan 1, 2008 | 11:59 PM
LS1Silverado05's Avatar
It can be done, but if the first time I would not expect that done in a day. Not doing it right anyway. You would do all that in a day including surface prep, chasing threads etc?...Heads/Cam/LTs? To the OP...It "could" be done in a day, but I would leave a weekend open. Just my friendly advice.
Old Jan 2, 2008 | 12:02 AM
socmguy's Avatar
Restricted User
I agree, first time job I'd do it over a weekend.
Old Jan 2, 2008 | 12:09 AM
ssheets's Avatar
He said later he wanted to do heads too. If you do heads and cam in a day I'd hate to see how long things hold together?
We did ring and pinion, long tubes, heads and cam in 6 days. It was slow, but PTV was measured accurately, all electrical connections were cleaned and lubed with dielectric grease. All bolts had their threads cleaned on a wire wheel and all bolt holes were cleaned and chased with a tap. Every fitting the GM put on the car was back on when we were done. So no speed records were broke, but it was a great week.
Old Jan 2, 2008 | 01:15 AM
slowjoe99's Avatar
I already have the LT's installed. I'll just be swapping the cam, LS6 ported oil pump, springs and such and also installing a SSF 3500 stall and tranny cooler. How many hours will installing heads add?
Old Jan 2, 2008 | 01:33 AM
socmguy's Avatar
Restricted User
dude, if you're doing a cam and stall, just drop the K member, it'll be way easier! Lift the car up over the K member and engine and while you're at it knock out the motor mounts.
