Bad IAC?
Old Jan 2, 2008 | 05:24 PM
stevied916's Avatar
Default Bad IAC?
I have had some problems with bouncing idle. I looked everywhere for vaccum leaks and couldnt find any. I even unplugged the the PCV hose from the manifold and the idle was still surging. I dont have a scanner to find the counts of the IAC but when I unplug the IAC when the car is running it idles a little high but it doesnt bounce anymore. Could i t be a bad IAC or would it have to due with my mail order tune?
Old Jan 2, 2008 | 06:31 PM
socmguy's Avatar
Restricted User
What all mods do you have and where'd you get your tune from?
Old Jan 2, 2008 | 06:36 PM
stevied916's Avatar
Ported TB, LS6 intake, LT's. I got the tune from W4M. I cleaned the IAC and the inside if the TB. I unhooked all the vaccum connections on the manifold and plugged both ends and there the problem is still there
Old Jan 2, 2008 | 06:37 PM
stevied916's Avatar
I also sprayed a crap load of carb cleaner where the manifold mates with the heads and nothing...
Old Jan 2, 2008 | 06:56 PM
stevied916's Avatar
K....well I took the iac odd the tb and pulled the plunger out till it would hit the hole in the tb (iac fully closed not allowing air to bypass tb). I then started the car with the iac still unplugged but installed on the tb and it idled fine. Does this mean I have a faulty iac or is it the tune?
Old Feb 3, 2009 | 08:03 PM
camaroIroc's Avatar
would like to know this too, i have same issue, mail order tune and high surgy idle.
Old Mar 4, 2009 | 05:17 PM
99SSragtop's Avatar
ttt
thanks
