EXHAUSTed & Confused
Old Jan 3, 2008 | 09:28 AM
T/AWS6969's Avatar
Unhappy EXHAUSTed & Confused
Well I am so confused on which exhaust to go with. I wAs almost dead set on going with the Rumbler x from TSP until i did a search and found a guy that had a 02 TA, like i do, and he had so many problems. I am i better to go with the Dynatech Supermaxx system or?? How many of you like the install of the Rumbler X? And how many of you still like it? I would still prefer to go true Duals. Thanks.
Old Jan 3, 2008 | 10:16 AM
teke184's Avatar
there really isn't an answer to your question.
for some reason, every exhaust fits differently on every car, particularly TDs. i think its just because the car was not designed for them.
big issues are pipe-frame clearances. which is completely dependant on the header...mostly collector location. other considerations are age of the motor mounts and how much engine movement they allow.
i have flowtech headers with a custom built X piped TD setup...fits great.
i just helped a buddy install the RumblerX on his Pacesetter headers...and the pipes were touching the frame just behind the driver-side collector.
basically...it is highly unlikely you'll get a 100% bolt up system that will give ZERO problems.
that's why i say have it custom built...then you can adjust as you build.
Old Jan 3, 2008 | 10:52 AM
chromeplated500's Avatar
+1 on custom. and just think, you can always adjust it down the road if you dont like it.
Old Jan 3, 2008 | 05:56 PM
T/AWS6969's Avatar
Default Hmmm
This has been looked at 59 times and only 2 responses. Who has the Rumbler x and happy with it? ..........Anyone......Buehler.........anyone...... ....Buehler..........................
