EGR or no EGR, that is the question....
Anyways, I have LS1Edit, along with my mods listed below... so I can easily edit the EGR out.
Three questions:
1. Does the EGR system even matter on my car as far as function goes due to the different cam, exhaust, and intake setup? In other words, will I tend to detonate more without the EGR setup?
2. I live in NY, do they "look" for a working EGR system during inpection? (They do the sniffer under a load test in NY)
Thanks for the info.
Tommy
PS I guess I cam Jerry rig some kind of EGR fitting into the new LS6 manifold if I have to, but I'd rather not bother if it doesn't make sense.
In NY they don't have a way for you to just hook up to the OBDII diagnostics? If they do, that would be the way to go. Then let edit do the work(make sure not to make any Edit changes at least two weeks prior to the test). Even so if anything is gonna fail you it's gonna be your cam. A visual inspection probably won't matter as 01/02 F-Bodies don't come with EGR. You can't expect an emissions employee to know the correct emissions setup of every car that could possibly come in there. As long as there's no code, he won't know and won't care.
I as able to pass MD inspection without EGR or AIR. they did the gas cap pressurization test , then hooked me up to the diagnostics port and 5 seconds latter I passed! Now NY rules might be different. But see what all you can get away with.
Mike
It's just a PITA having to worry about putting this stuff back on before inpection time...
Tommy
