universal plug wires
Old Jan 9, 2008 | 07:25 PM
blackbyrd's Avatar
Default universal plug wires
i tried searching but only found something about soapy water which didnt help me
ive made a universal set of wires and cant get the boot for the coil end over the wires it gets stuck and i cant get it to budge who knows a trick
Old Jan 9, 2008 | 07:31 PM
camarols1's Avatar
Try using some dielectric grease and twisting the boot between your fingers
as you push in the wire.
Sounds kinda kinky but it works for me!
You should be able to get this at the local parts store.
Even the so-so stores usually have it in one time use packs by the counter.
They may refer to it as "spark plug boot grease".
Good luck!
Old Jan 9, 2008 | 07:48 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Good luck!
YUP..
Old Jan 9, 2008 | 08:05 PM
blackbyrd's Avatar
i'm still having a bit of trouble..the grease helped some..does anyone have any other ideas??
Old Jan 9, 2008 | 08:21 PM
NHRAMAN's Avatar
Exclamation
more grease..keep trying..maybe stop for an hour or 2..then try again..it will come.
Old Jan 9, 2008 | 08:24 PM
blackbyrd's Avatar
thanks for the help! im getting it now!
Old Jan 9, 2008 | 08:25 PM
NHRAMAN's Avatar
Thumbs up
Just relax...stop...try again a few minutes after doing something else.
Old Jan 9, 2008 | 09:41 PM
Hilton's Avatar
Tough Mudder
I made a set for a friend a couple years ago. I stuck needle nose pliers through, opened them, grabbed the wire with the pliers, then pulled it through. Vasoline helped.
 Michael S. Palmer
Old Jan 10, 2008 | 07:16 AM
blackbyrd's Avatar
i got them done thanks guys
