Powdercoated FAST 90
Here's mine, ported and painted by Tony Mamo:
Intake
I swapped the black oxide hardware for ARP stainless 12pt bolts and nylock nuts:
Tony installs M6 x 1.0 threaded inserts in the throttle body flange, very nice feature:
The ARP hardware looks
Intake
I searched by could not find it, my FAST bolts are rusting aready. I would love to get some nice SS bolts.
Did you have to take the manifold apart to get it powder coated? Can the internal gaskets handle the 400* baking of the powder coating?
He had a standing offer to do the first FAST for FREE, I did not even know it till I asked how much & Mike said $15 shipping
He has done many LS6, but this was his first FAST 90It's actually some kind of advanced polymer
I never even asked, and since I got the free promo deal it never came up
Thanks Everybody
If your interested you can contact Mike at www.thepowdercoater.com
http://forums.corvetteforum.com/show....php?t=1904158
Here is the ARP bolt information:
Intake manifold bolt kit: 430-2101 (M6 x 1.0 x LONG)
If using nylock nuts for upper to lower bolts:
2 each: 770-1001 (M6 x 1.0 x 20mm) - These are ARP bulk packs of 5 each so you will have 4 bolts left over.
6 each: M6 x 1.0 stainless nylock hex nuts from the local hardware store
If using standard nuts for upper to lower bolts:
2 each: 770-1017 (M6 x 1.0 x 16mm) - These are ARP bulk packs of 5 each so you will have 4 bolts left over.
6 each: M6 x 1.0 stainless hex nuts from the local hardware store
However I did make gains without adding boost, still at 9.4psi. My goal is to make 700rwhp at 10psi or less with V2 S-Trim by having max efficient setup...still working on a couple of different angles that I expect will yield a little more power
