broken bolt in head
Old Jan 13, 2008 | 08:29 PM
firemedic0135's Avatar
Default broken bolt in head
got a header bolt broke in the head and it is actually countersunk a tad.
the shop that broke it off also broke an ez-out in the bolt I know its fucked up but has anyone had any luck having/removing something like this?
I have replaced the heads but wondering if I can salvage these for the old shortblock or if just need to take them to the scrapyard.
thanks
Old Jan 14, 2008 | 05:50 AM
BLACK2001SS's Avatar
You could try to drill it out need some realy good drill bits then retap it.
Old Jan 14, 2008 | 05:57 AM
qwk93ta's Avatar
I did this in a Ford Lightning I had many years ago and a good machine shop can fix this for you.
Old Jan 14, 2008 | 08:26 AM
jshelton2006's Avatar
i broke one off in my head when installing headers but it doesn't leak or anything so i left it...
Old Jan 14, 2008 | 09:11 AM
Jays00ss's Avatar
use a good oil penetrate and then use a good drill bit and easy out. Snap on makes a wonderfull set of easy outs that you can use a socket on. Happens on our Aircraft all the time.
Old Jan 14, 2008 | 01:36 PM
socmguy's Avatar
Restricted User
This happened to me while I was working on a friends car. Instead of pulling the head and extracting it I ended up dropping the motor and K member about 18". Drilled it out extracted it, and retapped. Had the whole car back together by midnight.
Old Jan 14, 2008 | 03:52 PM
styoung's Avatar
well, if they broke it its there responsibility, i would make the shop fix it. it the ez out is broked in there in is not gonna be fun to get it out, trust me i know. but i would let the shop that broke it fix it.
Old Jan 15, 2008 | 04:12 AM
I am not terribly worried about it as they made me a killer deal on some GMPP heads and ls6 intake and did the header install all for 1k.
They are good folks and I knew that was a possibility going in and thats why I took it to them.
Old Jan 15, 2008 | 04:34 AM
Its a pritty good deal but still they broke it so they should fix it.
Old Jan 15, 2008 | 06:32 AM
LS1MCSS's Avatar
If there is an ez-out broken off in the hole, you won't be able to drill it out. The ez-out is a lot harder than the drill bit. You can let the shop try to get the old bolt out, but plan on the head getting destroyed.
Old Jan 15, 2008 | 03:38 PM
styoung's Avatar
true, but you MIGHT be able to drill it out with a cobalt drill. but it wont be fun.
can you get vise grips on the ez out or the bolt?
Old Jan 15, 2008 | 04:33 PM
I've had easyouts brake befor and buy some miracle I got it out but I couldent tell you how it happend because I tryed everything to get it out and depending on how its broke will make a huge diffrence like if any is sticking out still.
but it basicly sounds like they cross threded it so they should take responsibility and fix it thats all thier is too it, I'd be like sorry guys I know you were giving me a deal but you broke you have to fix it. And make shure they show you how they fixed it dont let them get away with some JB weld fix.
Old Jan 15, 2008 | 05:45 PM
you are right I just dont wanna be an ******* .I was reading on the www somewere today about using a plasma cutter to blow it out.sounds scary to me
Old Jan 15, 2008 | 06:33 PM
haha plasma and aluminum haha I can just see the mechanic now handing you a big glob that was your new head lol like here ya go we fixed it real good hahaha.
Old Jan 20, 2008 | 10:27 AM
tording99Z28's Avatar
A machine shop should be able to get it out for you. A friend of mine did the same thing, a machine shop was able to drill it out, retap it and helacoil it and he never had a problem.
