intake manifold & TB
Old Jan 13, 2008 | 09:37 PM
chvycmaroz28's Avatar
Default intake manifold & TB
i was thinking about getting a ls6 intake manifold eiter te 78 or 90mm....now how muc hp gain have u guys seen from that and if i do that do i have to get a bigger and same size tb also? and i wanna get it tuned after this right?>
Old Jan 13, 2008 | 09:42 PM
WhosNXT's Avatar
The ls6 manifold is 78mm. They do not make a 90mm version. You will generally see a 15hp gain over a ls1 intake. Your stock throttle body will work with the ls6 manifold, you might want to look into getting the stock tb ported. This will also add 7-10 hp.
Old Jan 13, 2008 | 10:13 PM
motoo344's Avatar
If you plan on doing heads and cam, the FAST 90/90 would be a good choice. If you are going to do just bolt ons to a mild or medium cam ls6 and ported stock throttle body would be nice route, probably the cheapest also. I just installed a ls6 intake and it was well worth it, better throttle response, you will notice the increase in power.
Old Jan 14, 2008 | 05:43 AM
BLACK2001SS's Avatar
If you have a ls6 intake allready you can send it off to tpis right now for like 300 to get it made into a 90 then get a 4 bolt TB for 500 and on paper its gains are clost to the fast.
Old Jan 14, 2008 | 06:57 AM
Shawn @ VA Speed's Avatar
unless you have ported heads,a bigger tb isnt going to help,we have run stock tb's on ls6 intakes into the 420range and then swapped to fast 90/90 and only picked up a couple,not worth it in my opinion
Old Jan 14, 2008 | 08:24 AM
jshelton2006's Avatar
find a used ls6 intake, probably around $350ish...
