Will my setup lope??
Old Jan 15, 2008 | 12:30 PM
landonew's Avatar
Default Will my setup lope??
Setup is in sig. Heads/intake are in the process of being ported and everything will be installed, and I was just wondering if anyone has run a similar cam. I think this custom grind is really similar to the f13 (130/132 w/ 114 lift). I have been to ls1sounds.com, but is difficult to tell. Does anyone know if this cam will lope decently (assuming good tune) w/ long tubes (no cats) and TDs?
Old Jan 15, 2008 | 01:57 PM
00Formula00's Avatar
You might want to recheck the spec on the F13, but yes, your set up should lope...Especially more than a stock setup... If you really like a "slappy" cam consider a 112lsa
Old Jan 15, 2008 | 02:08 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The 230/232 on a 114 will definitely be noticeable, but not dramatic. It will depend on where they set your idle when they tune it as well, the lower the idle the rougher it will sound
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 15, 2008 | 02:51 PM
landonew's Avatar
Advantage/disadvantage to low idle? What is the lowest practicable?
Old Jan 15, 2008 | 03:41 PM
99mongooSS's Avatar
low idle with small lsa will idle more rough so the 112 at 900rpm's will idle hard but at 750 it will idle real hard.
Old Jan 15, 2008 | 03:44 PM
JScamaro's Avatar
The more overlap a cam has the more it will lope.
The stock cam has ~ -30 degrees of overlap. Your 230/232 114 lsa will have 3 degrees of overlap so it will lope more than stock but nothing like the t-rex cams out there that have 25 degrees of overlap.
Old Jan 15, 2008 | 03:46 PM
99mongooSS's Avatar
yep or ms4's i love my cam!
Old Jan 15, 2008 | 04:46 PM
Arctic2002ss's Avatar
I have actually tried to keep mine rather mild so that's why I went with a "smaller" cam and 114lsa. See sig for all mods. It does not lope much because the idle is set around 1,000rpms. It would lope a lot more with a lower idle. It is still obviously cammed though. I don't think you have anything to worry about.
Old Jan 16, 2008 | 01:18 AM
12secSS's Avatar
Check my sig for an idle video. I have an F13 with a 112 on my A4, and it idles at 800 rpms. Depending on how good your tuner is, you may not be able to notice the lope as much. You can kind of hear it in mine, but not as much as you would expect. You want the idle high enough that it doesn't stall due to the overlap, I settled on 800 rpms on mine.
Old Jan 16, 2008 | 03:03 PM
landonew's Avatar
IF IT SOUNDS THAT GOOD I WILL BE ECSTATIC! Wow, that is perfect. not too much lope, but enough to know that it is a bad SOB!! But your lsa is 112, so i am sure mine won't sound quiet as good.
Old Jan 17, 2008 | 05:01 PM
1stz06's Avatar
I am going to be very curious to see what your final numbers are. Please keep us posted!
Thanks,
J.R.
