will this work?
Old Jan 17, 2008 | 09:00 AM
Nick_Rapitis's Avatar
Default will this work?
if i put this in click here will it make it so i can pass my emission test?
Old Jan 17, 2008 | 09:26 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I take it you are removing your cats? If you just need the SES light to go out so you can pass then yes, it will. If they do a sniffer you would still fail. If you remove them completely instead of gut them you would still fail a visual.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 17, 2008 | 09:30 AM
no i just got a o2 heater sensor circuitry malfunction code...would this eliminate that?
Old Jan 17, 2008 | 10:12 AM
05RST's Avatar
It might but it could be just a bad o2 sensor and they are not that much money to replace them. or it could be that you have a short in the wiring going to the o2 sensor. have you checked that out yet?
Old Jan 17, 2008 | 10:16 AM
no it just happened last night so im not sure what the problem is exactly
Old Jan 17, 2008 | 10:33 AM
The code was specific to one side right? IE, bank 1 or 2? IF it was swap the sensors and see if the code changes to the other side. If it does, you have a bad O2. This way you don't have to buy one without knowing that you need it first
__________________
Old Jan 17, 2008 | 11:57 AM
would i be able to just switch them myself? i dont know about any of this stuff, i just got the car a couple days ago and have no experience with ls1s
Old Jan 17, 2008 | 12:04 PM
Pntbll309's Avatar
Takes about 10 minutes to do, as long as none of them take too long to get off.
 Michael S. Palmer
Old Jan 17, 2008 | 12:12 PM
I'm sure you can, you just need a wrench the right size to take it out of the exhaust and then you unplug the sensor and swap them. Pretty simple but if you have an older LS1 (00 down) one of them might be a pain to get to.
__________________
Old Jan 17, 2008 | 12:38 PM
can i clear the codes by disconnecting the battery for a short time?
Old Jan 17, 2008 | 01:07 PM
Soul TKR's Avatar
I don't believe the codes will clear... like said above, get under the car and swap out the sensors with each other... it's not hard at all... it's as simple as unscrewing, swapping, and screwing back in...
Old Jan 17, 2008 | 03:20 PM
05RST's Avatar
No it will not work to just disconnect the .battery to clear the codes. You are going to have to take it down to your local auto part store and they can clear it for you
Old Jan 17, 2008 | 03:24 PM
yeah, its going to my mechanic tomorrow since i dont have the time, or weather to work on it myself...stupid crappy ohio weather and stupid crappy college wasting my time lol
Old Jan 17, 2008 | 03:25 PM
Pntbll309's Avatar
Its time to man up and learn to work on your car bud. O2's arent hard to swap at all. I believe they cost about $45ish from an Autozone. All you need is a wrench and some elbow grease.
Old Jan 17, 2008 | 03:26 PM
jermzz's Avatar
Yes. disconnect the battery for ten minutes and the SES light will go off and stay off til another code is thrown. I think the codes will still be in the PCM though. not sure about that.
