help which intake?
Old Jan 19, 2008 | 01:24 AM
KingSumthn's Avatar
Default help which intake?
i have a n ls6 intake manifold with the stock ls1 camaro throttle body. im pretty sure the ls6 intake manifold flows better than the ls2, but im wondering since the ls2 uses a 90 mm throttle body would i get more power with the ls2 intake? also what size is the ls1 throttle body? i believe its 75mm?
Old Jan 19, 2008 | 06:33 AM
Red99TA's Avatar
I think the LS1 throttle body is around 78mm max but necks down a little less than that. The LS6 flows very well and I'm pretty sure it's just as good or better than the LS2. I thought I saw a comparison between the two somewhere. Just do a search on here and I'm sure you can find something.
