Wiring????
Old Jan 19, 2008 | 07:14 PM
dreamls1's Avatar
Default Wiring????
Hey guys, ok here is the deal. I am converting my 94 3.4 firebird into a turbo trans am with LS1. I want to put in My own gauge cluster using autometer gauges,(speedo, oil, etc) i will have not heat or A/C. Should i still get and 99-02 wiring harness that runs behind the dash and hard wiring the gauges up to that. Or do i not need that harness? please help.
Old Jan 20, 2008 | 10:33 AM
tording99Z28's Avatar
If you are going to use autometer guages then why use the stock harness? If you were going to try and use the stock guages from a LS1 cluster then I would say yes. Since you want to run autometer guages just run wires and wire all the guages up using the senders that come with them and call it a day. I don't really see a need to try and use the stock harness to do this with.
