CME Question
Old Jan 21, 2008 | 11:41 PM
JScamaro's Avatar
Default CME Question
I have the slp cme tips and plan to match it with my gmmg. I saw SLP has a 90 degree bend for sale but it only says left side.
Can I order two of these? Will they match the cme to my gmmg?
http://www.slponline.com/view_produc...63&BIG=10863-1
Old Jan 22, 2008 | 05:53 AM
Grifter's Avatar
I am not sure if it will work with the CME. You can give SLP a call or do a search and see if anyone on here has used it. That custom setup has been done several times, so I am sure someone knows.
If they don't work I would take the car to a reputable exhaust shop and them make everything fit.
Old Jan 22, 2008 | 09:40 AM
camcamaro1991's Avatar
Post Cme
No They Are Not The Same,
There Is A Left Side, And Ther Is A Right Side.
YOU CAN SEE IN THE PICTURE THAT ONE PIPE IS STRAIGHT THEN TURNS 90 DEGREES TORWARDS THE END, AND THE OTHER CURVES THROUGHTOUT THE PIPES 90 DEGREE BEND.
Old Jan 22, 2008 | 10:24 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Don't worry about those bends...if you want mandrel, just pick up a couple of 2.5" 90 degree mandrel bends, take it all to a good exhaust shop, and they'll take care of it.
