Bad O2 sensors causing idle problems?
Old Jan 22, 2008 | 12:05 PM
Cerebrex's Avatar
Default Bad O2 sensors causing idle problems?
I have a heads/cam ls1 that was running fine for quite a while until last week when I got an SES light. I checked the codes and they were for the front O2s (I don't have rears). Well since then the car has developed a real low idle, and when I give it gas it takes a few seconds for it to respond, which it usually does by lunging a little at that point. It seems like it's missins a lot throughout the lower RPMs. Do you guys think this problem is attributed to bad O2 sensors? If so, how? Thank you very much for any replies.
Old Jan 22, 2008 | 12:12 PM
W105's Avatar
Yes! I just had the same exact problem, put new O2 sensors in and she runs fine now.
Old Jan 22, 2008 | 12:21 PM
BLACK2001SS's Avatar
also for the hell of it check your maf and cleen it along with your TB thats what I'd do. make shure to unhook your battery befor removing your maf and hook it back up befor you put the battery back on.
Old Jan 22, 2008 | 12:24 PM
94'BLKBRD's Avatar
sounds like o2 sensors...get the corvette bosch sensors
Old Jan 22, 2008 | 06:34 PM
silverLSWON's Avatar
i think i need o2s also. i keep getting a p0300 code(multiple missfire) and feels like it stumbles at idle a little bit. i'd say you need 02's, i think there like 45 bux each from gm
Old Jan 23, 2008 | 05:28 PM
Cerebrex's Avatar
they were 70 something a piece at Autozone. Lame.
Old Jan 24, 2008 | 08:19 AM
Dom's Avatar
Dom
What are the stock replacement ones for us? I don't want Bosch. Anyone has a GM part number?
