true duals ?
Old Jan 24, 2008 | 06:21 PM
98MNBZ28's Avatar
Default true duals ?
is there a advantage or disadvantage to running true duals str8 to the back w/o x or h pipe?
Old Jan 24, 2008 | 08:20 PM
SOMbitch's Avatar
X pipe + TD's = best power. H pipe +TD's = best sound. TD = a little more power over good Y and catback. Drawbacks are more $$$ and less ground clearance especially an issue if you are lowered. A cutout + Y setup can bridge the gap and give you the most HP when you want it so consider that also.
Old Jan 24, 2008 | 08:27 PM
Cmhatter9SS's Avatar
so the best is X?
Old Jan 24, 2008 | 08:33 PM
dutinsss's Avatar
Originally Posted by Cmhatter9SS
so the best is X?
its all an opinion. i would say the best is an H, because i care more about the sound more than a little more power in the top end. i've never compared H vs. X in terms of power, but i wouldn't think it would be that noticable
Old Jan 24, 2008 | 08:42 PM
bowtiepastya's Avatar
you can easily run duals with an x or h pipe and either dump it at the axle or out before the rear tires...
ive heard that an x-pipe is beter and it fits well in the drive shaft valley giving a little more clearance but i have no proof of which is better.
all in all true duals are a possibility and definatly flow better than a y-pipe system
Old Jan 24, 2008 | 09:44 PM
skyhighsami's Avatar
no title here
Does the Texas Speed True Dual setup fit pretty well? I have a UMI TA and the MAC Y pipe rattles like crazy on it and I would like to get something that would have clearence around that when I get LTs.
Old Jan 25, 2008 | 12:55 AM
SSMOKIN_Y2KSS's Avatar
i like the h pipe better than x but once again thats only an opinion
Old Jan 25, 2008 | 10:08 AM
C's35thSS's Avatar
Im about to put LTs on and was wondering what I need to do a side exit infront of the rear tire? I didnt want to use cats. It will all be done with custom pipe. Do I still need an X or H pipe? Any help please
 Michael S. Palmer
Old Jan 25, 2008 | 10:14 AM
dutinsss's Avatar
yes, its always better to have a connecting pipe, whether it be X or H
Old Jan 25, 2008 | 11:56 AM
RareBreed0295's Avatar
Its worth it. I had duals without a crossover pipe at first. just had an H put in it and its a totally different sound. Get a crossover.
