possible ignition problem, hestitation and popping
Old Jan 28, 2008 | 01:12 PM
thebrownone's Avatar
Default possible ignition problem, hestitation and popping
hey guys, one of my coil packs came loose and was sitting against a header for a few miles, car was running perfect before this, i bolted it back up, it ran better but its not the same. it pops when i start it up, harder to start, and i get hesitation when i punch and im pretty sure worse gas mileage. so far i checked my plugs, wires, cleaned my maf, and swapped coils around, nothing seems to help what could it be
Old Jan 28, 2008 | 01:20 PM
badaSS346's Avatar
Well if you have a bad coil...swapping them around wont fix the problem just move it. If the car misses and stumbles at idle, swap the coils around to try and find the bad one. make sure that the wire on the coils end clicks twice.
Old Jan 28, 2008 | 01:27 PM
1320 killer's Avatar
barrow a set of coils froma friend and try them out. that will tell you if that is the problem.
