two step rev limit???
Old Jan 31, 2008 | 06:33 AM
Smoke346's Avatar
Default two step rev limit???
I used to have a 10s 69 BBC camaro, I launched off a brake and used a two step to keep my launches consistent. I now have an 02 SS M6 and am curious to know if there is a setup I can get for the stock ignition where I can set up a two step or just a rev limit activated by a button to keep my launches more consistent, esp since the SS is a M6. Thanks in advance.
Old Jan 31, 2008 | 07:27 PM
Top Fuel's Avatar
I have the Lingenfelter one. very easy install
Old Jan 31, 2008 | 08:23 PM
5.3LJimmy's Avatar
I have a Harlan Engineering 2-step, but he doesn't make them anymore. I think Synergy Motorsports makes a similar design to mine and I see them quite regularly in the classifieds on here. The way mine works is with a momentary push button to activate and the clutch pedal switch to deactivate. Just hold down the clutch, then push and release the on button, floor the accelerator, drop the clutch, and wish you had traction. I tried looking on Synergy's website, but didn't see a 2-step listed. Ligenfelter does still have them.
