So confused....PCV issues
Old Jan 31, 2008 | 10:09 PM
Parrothead497's Avatar
Default So confused....PCV issues
Ok,
So I finished my head/cam swap last weekend. Did not know I had to update valve covers when I did it So now I need to figure out what to do with the holes I have in the 99+ valve covers. The pcv system from my 98 setup will not work. I am very confused on what I should do here. I've tried the search, but it only seems to get more confusing. What do I need to do? This car is my DD and I need it up and running again! I really don't want to pull the intake again so I think the LS6 is out of the question.
Any help would be greatly appreciated.
Thank you
Old Jan 31, 2008 | 11:16 PM
RedRallyeZ's Avatar
get a breather from EPP and get rid of all the PCV lines, i like that setup better than i did with my old lines and crap, its on EPP's site under the appearance section. it just replaces the oil cap and elbow. pretty good looking too.
Old Jan 31, 2008 | 11:18 PM
BarneyMobile's Avatar
You can run a breather setup on the valve covers(cheap & easy), or you can go the dealer and buy a 99+ pcv setup.
Old Jan 31, 2008 | 11:19 PM
MM98's Avatar
^^What they said.
Old Feb 1, 2008 | 12:36 AM
socmguy's Avatar
Restricted User
If you show your car I recommend you do the PCV system. Breathers will make a mess under the hood after a track session.
