catchcan
Old Feb 2, 2008 | 09:36 AM
snake3126's Avatar
Default catchcan
i was just doing a little research and i ran across a catchcan, great idea, i understand howo they install except for which hose from the krank they hook up, and are they worth the money, little info would be helpful
Old Feb 2, 2008 | 09:43 AM
TLewis4095's Avatar
The catch can is to reduce the amount of oil contaminated charge entering the intake manifold. It is designed to run inline between your PCV valve & the valve cover fitting that went direct to the PCV valve.
