tps sensor maybe??
Old Feb 3, 2008 | 11:42 AM
021less's Avatar
Default tps sensor maybe??
Just wondering if anyone else thinks my tps sensor is bad. Here is a vid of it.
http://s117.photobucket.com/albums/o...t=101_2384.flv
It has an ms4 cam, and tuned by vengeance. What it does is when you first crank it, it will not idle, but give it about 20 seconds or so, and it will then idle on its own. I just got used to it and thought i was just cause of the cam. But a guy on another forum told me it sounded like a broke map on the tps sensor. What is everyones thoughts???
Old Feb 3, 2008 | 12:01 PM
Lt1Porsche's Avatar
Doesnt sound like a bad MAP or TPS to me. Both of those sensors would cause drivability problems.
Old Feb 3, 2008 | 12:41 PM
021less's Avatar
that is what i figured, but the car does drive fine.
Old Feb 3, 2008 | 06:49 PM
Lt1Porsche's Avatar
Could be a tuning issue. I have seen a slightly malfunctioning IAC effect cold starts but chances are thats not your problem. Chances are its dealing with the cam and the tune.
