Need different location a/c compressor outlet
Old Feb 6, 2008 | 01:06 PM
popeye's Avatar
Default Need different location a/c compressor outlet
I have a 2003 5.3 from a yukon and the factory compressor outlets hit my upper control arm bracket. I have looked at the camaro and corvette compressors with rear port locations, would they bolt up to my current brackets and would the belt line up?
I also need to know if the compressors are a fixed displacement. Vintage Air says it needs to be fixed not variable displacement to work properly with their under dash evaporator.
