New Intake/throttle body......TPS question
Thanks
Yes, that will work followed by an idle relearn procedure. The above is done when people use the set screw on the TB to open it up a bit to idle better. Say you open the blade up to 3%; you can use the above to reset the car to think that 3% is now zero.
idle relearn:
MN6,
start engine with AC OFF, let it idle for about 5 minutes.
Then you want to turn AC on full blast (coldest setting) and idle for 5 minutes. This allows PCM to calibrate with the idle trim cells
