Do pacesetters give good gains
ill probably get flamed for this but go on the for sale section. look at some of those "STAINLESS STEEL" headers that every raves about. most of them look like **** too.. a shinier header doesnt mean its gonna be that much faster. if mines rust then it rust, oh well. its not a damn show car anyways..
Headers themselves work great w/ true duals or a customer made 3 inch Y.
LOL, nut swing much?
When a person buys a header there is more then price and when you take in all factors you pay for what you get, a cheap header = cheap quality.
LS1's are known to vary in power quite a bit and that can explain the "few" that may have done better.
The car is a DD in the good weather months. I have uncoated headers and they still have no rust on them. A friend of mine installed his coated Pacesetters at the same time and his are already turning that goldish color. I'm not saying coated is bad because they are clearly better but if your on a tight budget painted are not a bad option either. IMHO, most people are going to try to justify the purchase of the parts they've obtained by justifying them in some way or another. I think you should consider what your goals are: how long are you keeping the car?, stainless is a good option because they'll last longer than coated; how much $$$ do you have? Pacesetters have got to be near the best bang for the buck; are you lowered?, maybe ground clearance will be an issue and three-inch Y-pipes won't be a good option; do you care about how they look?, polished stainless looks good as long as it's polished and cleaned-they'll discolor to a gold to bronze color after a few heat cycles while coated headers will retain their finish until they begin to rust; what kind of environment will the car be used in?, is there road salt or do you live near an ocean-if so, stainless will have more durability than coated because the coating will eventually flake.
Yeah, I've had two sets of QTPs (standard and HVMCs) but I'm not going to try to sway you to stainless. If you don't keep your car longer than a could years, the $1100+ for a complete LT/Y-pipe kit in stainless isn't likely worth the money over some coated Hookers or Pacesetters. Hooker and Edelbrock also have started offering stainless too. You aren't going to get too much more power from one to another, for the most part, among all of them. HVMCs are cool except it is said that they aren't the end-all-be-all design because every engine requires different tuning in the placement of the collector so the same HVMC header to two different cars may not even net the same results because they are in different cars.
Sorry so long, but there are a lot of variables to consider.
Good luck.
Wow a 12.7 from headers!! Holy **** those gave you like 300 gabillion HP... Considering a good tire and driver can get into the 12's. Im not saying Pacesetters are the worst out there, but if you could get a better product with better materials cheaper, then why not?
exactly!! pacesetters FTW!!!
