What sensor is this?
Old Feb 21, 2008 | 02:42 PM
Erikz 28's Avatar
Default What sensor is this?
I broke it doing the header install... Its on the driver side, front of the head, next to the first primary??? Is it a big deal or what?
Old Feb 21, 2008 | 02:50 PM
tylerdj's Avatar
Sounds like your coolant temperature sensor.
Old Feb 21, 2008 | 02:51 PM
2001NBMZ28's Avatar
ECT sensor, PCM needs it's input - cheap and easy to replace.
Old Feb 21, 2008 | 02:52 PM
5.3LJimmy's Avatar
He's correct^^^. It's a very big deal, but not an expensive part.
Old Feb 21, 2008 | 02:56 PM
99ZEOD's Avatar
Temp sending unit. Yes you need it. It only costs about $20 for a new one. Make sure you bleed the coolant after you replace it.
Old Feb 21, 2008 | 03:18 PM
socmguy's Avatar
Restricted User
Glad someone said it. Bleed the coolant!
Old Feb 21, 2008 | 03:55 PM
Erikz 28's Avatar
ok, thanks guys
