question about ls6 valve covers
Old Feb 21, 2008 | 09:19 PM
quiet_storm98's Avatar
Default question about ls6 valve covers
I have a set of gmpp valve covers that i will be installing when i do my h/c and i was told that i should get a ls6 valley cover and pcv valve as well as run a breather off the oil cap. I know that the breather is supposed to relieve some of the crankcase pressure which is why i will probably run one but does a ls6 have provisions for the pcv in their valve covers or are they the same as a ls1's valve covers? If they dont have the holes for the pcv then running an oil cap should be just fine.
Old Feb 21, 2008 | 10:25 PM
TLewis4095's Avatar
You still need to pull metered vacum to evac the vapors.
The LS6 style valley cover would be a good choice since it is baffeled & has a metered orfice to control the amount of vacum. Them you should have a small breather in the drivers side rear so filtered fresh air folws through as much of the crankcase as possible.
Old Feb 22, 2008 | 01:03 PM
o ok thanks so i guess i still have to run a breather then
