Harmonic Balancer Install
Old Feb 23, 2008 | 01:39 PM
bluethunder364's Avatar
Default Harmonic Balancer Install
I need a installer and was just wondering if anyone had a source for these. What is the thread size at the end of the crank? I tried a loaner one at Advanced Auto and it did not work. None of the threaded tips to install at the crank end worked. If I have to I'll buy one and maybe just resell it when I'm done. Any info would be much appreciated. Thanks
Old Feb 23, 2008 | 03:21 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Here you go...
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html
Place the balancer onto the snout by hand and then thread that all the way into the crank snout. Slowly start to turn the nut down and it will pull the pulley onto the crank. Just an FYI, these aren't really balancers since the crank is internally balanced. More accurately it is a dampner/pulley.
