Bellhousing cover?
Old Jul 17, 2003 | 03:12 PM
Nickn20's Avatar
Default Bellhousing cover?
I think this is posted in the right area, so basically im putting a car back together, and I found the cover for where the starter goes that covers the flywheel, but on the other side of the bellhousing by the oil filter the flywheel is exposed also, and I cant find the cover, anybosy got a part number for this? I would imiagine it doesn't hurt to keep this off maybe helps keep the clutch cool? any ideas on what I should do? put the cover on or leave it off?
Old Jul 17, 2003 | 05:33 PM
LOnSLO's Avatar
Default Re: Bellhousing cover?
You mean that little black plastic cover? That helps keep dirt and water out of the bellhousing, so definitely a good idea to replace it. You could probably just rig something up to work though.
Old Jul 17, 2003 | 05:49 PM
felton316's Avatar
The one by the oil filter is: 12558718
