Cutout/Catback Install Questions
Old Feb 28, 2008 | 01:29 AM
bluestrat's Avatar
Default Cutout/Catback Install Questions
I recently purchased a hooker catback and a manual cutout. I plan on installing the cutout in the famous spot in the I pipe under the rear seat. I found a guy that will weld the cutout in the I pipe for $50. Is that a fair price? Should I keep looking?
Also, What's involved in installing the catback? I've read you basically need to cut the stock one off then it all goes in pretty easy. I have no use for my stock catback so I don't mind Hacking it up.
Thanks in advance!
Old Feb 28, 2008 | 02:45 AM
waldershrek's Avatar
Na that sounds good. Installing the cat back is easy and so is the cut out for that matter but unless you know how to weld $50 isn't bad.
Old Feb 28, 2008 | 05:30 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
not a bad price. Get er done!
Old Feb 28, 2008 | 06:50 AM
GregWS6&z28's Avatar
$50 is fine. it's a little bit of work to do.
Old Feb 28, 2008 | 07:27 AM
billyb's Avatar
Default like this 4" dmh electric c/o
