is it worth it to go electric waterpump?
Old Jun 22, 2008 | 02:19 PM
Funkster's Avatar
Lots of HP upgrades should come before a EWP. Either way, get yourself an adjustable panhard bar and fix the rear end grind first. (Mine used to grind and my rear end was off almost an inch!) Then worry about the electric water pump.
Old Jun 22, 2008 | 03:05 PM
ealucero1's Avatar
I have had that problem with the rear tire grinding on stock rubber. My rear end shifted to the left and caused the right to grind on sharp turns. If you go behind your car and you see more tire on one side than the other then thats it. My was corrected with a new sway bar, the end link had broken in half and tweaked the rear end and inch or so to the left.
