LG Pro's Problem
Old Mar 5, 2008 | 01:47 PM
CobraB8_ZO6's Avatar
Unhappy LG Pro's Problem
Ok, this is gonna be long......here goes, I bought a set of LG pro LT's with catted x-pipe. The guy i bought them from told me to put the rear O2 sensors in the the bung and im guessing plug them up to the front harnesses but the bungs are so far down stream on the header that the plug in wont reach the sensor......the guy gave me some kind of adapter plug that is about 1 1/2 inch long that i dont know what it is used for. i have a DTC code scanner and the car is throwing the front and rear bank O2 sensor codes. I really need to get this fixed. Thanks in advance!
Old Mar 5, 2008 | 01:53 PM
LS1-NAVY's Avatar
tune them out
Old Mar 5, 2008 | 02:00 PM
Can you tune out the front ones? I figured i would have to get a harness extension or o2 sims.
Old Mar 5, 2008 | 02:04 PM
OUTLAWZ RACING's Avatar
Ok what? Do u have the front o2 s hook up I hope so u need them for the car to run good now the rear o2s u can have them deleted out with software Ie hp tuners or ls1 edit. that should fix your problem.
Old Mar 5, 2008 | 02:07 PM
I do not have them hooked up. My question is, is there a extension that i have to buy to get the hookup to reach the sensor?
Old Mar 5, 2008 | 02:08 PM
DarkJuggalo's Avatar
have it tuned out or get extensions ;D speed inc has them --->
Old Mar 5, 2008 | 02:16 PM
Thanks a lot bro!
Old Mar 5, 2008 | 03:27 PM
Will i need the 12" or 24" extensions
 Michael S. Palmer
Old Mar 5, 2008 | 08:26 PM
SOMbitch's Avatar
12" have always been enough for me and then you don't have to deal with zip tying all the extra wire out of the way.
