FAST differences
Old Mar 6, 2008 | 03:03 PM
FrankSS's Avatar
Default FAST differences
Hey guys... does anyone know what the difference is between the fast lower shells for the 78mm and 90mm intakes? Ive seen the shells sold separate, so i was wondering if you had a 78mm bottom, would the 90mm top bolt up??
TIA
Old Mar 6, 2008 | 03:06 PM
landonew's Avatar
Yes. As far as i know the only difference is the upper shell. I assume you will want to replace the gasket as well.
02silvaZ's Avatar
i think they are interchangeable but not positive
Old Mar 10, 2008 | 09:46 AM
radkon's Avatar
There is no difference in the lower or middle part of the FAST intake. The only difference is the upper shell has a 90 mm throttle body opening. I have used both top shells with the same lower and inner parts.
I'm not sure on the new 92 MM shell though.
