arp balancer bolt
Old Mar 8, 2008 | 09:16 AM
bumpin_records's Avatar
Default arp balancer bolt
I just installed the ati super dampener. I want to use the arp balancer bolt so do i order the regular ls1 arp balancer bolt part number 234-2503 cause that dont seem long enough ? thanks
Old Mar 8, 2008 | 01:28 PM
bigti99a's Avatar
well you need a "tool" to get the dampener all the way on the crank snout. like threaded rod, washers, and nuts. once on all the way, the stock length bolt will catch. check the cam install on ls1howto.com
Old Mar 9, 2008 | 09:58 AM
well i have the balancer on and the ati super balancer do not go on flush. My question is the balancer bolt. i dont get as many turns as i would thought i would with the arp balancer bolt part # 234-2503. Is that the right balancer bolt.
Old Mar 9, 2008 | 11:18 AM
massls1guy's Avatar
That's the right ARP bolt. I think bigti99a is right, you probably don't have the balancer all the way on. How did you install it, what method?
Here is a link to some ATI instructions on their site:
http://www.atiperformanceproducts.ne...structions.htm
>>ATI dampers must be retained to the crank with a standard length bolt torqued to the manufacturer's specifications.
Old Mar 9, 2008 | 01:07 PM
SOMbitch's Avatar
Balancer install can a real PITA for something that seems so simple.
Old Mar 10, 2008 | 04:05 AM
this is the tool i used https://ls1tech.com/forums/showthrea...stall+balancer
