Can i remove the vacume solonoid on the drivers side??
Old Mar 11, 2008 | 06:21 AM
WS6 Canada's Avatar
Default Can i remove the vacume solonoid on the drivers side??
Can i remove the soleniod thing on the drivers side intake at the far back. It has a line goning to the splitter valve for the AIR PUMP and the other going to ???? you tell me....
Also is there a Vac line on the back of a LS6 intake??
thanks
Old Mar 11, 2008 | 11:15 AM
thebart455's Avatar
i did not notice a tube on the back when i installed my ls6 intake, i do know that you have your oil sending unit on the back but when i removed my egr and air i had no tubes on the back
Old Mar 11, 2008 | 11:41 AM
tylerdj's Avatar
If you removed your AIR then you can take that off. There will be a small vacuum line going to the back of the intake that you should plug. I just used a small screw that fit tightly into it and sealed it with a little rtv.
