H/C swap questions
Old Mar 13, 2008 | 12:26 AM
MrElectric03's Avatar
Default H/C swap questions
I am about ready to order my parts for my head and cam swap for my 01 WS6
What I have decided on so far is the PRC stg 2.5 5.3l heads. At this time I will install new oil pump, LS7 lifters, LS2 timing chain, hardened pushrods, new head bolts, UD pulley with new bolt, Z06 MAF, and QTP longtubes. After the swap is done it will go to Ryne at CMS for a true dual over the axle system and dyno tune.
I already have the usual bolt ons:K&N, SLP lid, ported TB, smooth bellows.
First...I am deciding on a cam...I have narrowed it to either TSPs 228R or having Patrick G spec out a cam.I think I am going with the custom as it will only run me an extra $65 for it but would like some opinions from those who have done it.
Second...What compression ratio should I run. I was thinking 11:1 or close to it. I can have the heads milled to 59cc and get an 11.2:1 wih the GM MLS gaskets or I can pay more for the Cometic .040" and get 11.1:1 with the heads un-milled but the gaskets cost over $100 extra.I have heard it is better to use thinner gaskets so that I dont loose quench. I really dont understand this part and would be greatfull if someone could explain...opinions please?
Thanks very much in advance...I have tried searches but cant get straight answers to my questions.
Old Mar 13, 2008 | 08:28 AM
Bump...
Old Mar 13, 2008 | 05:15 PM
Bump...come on somebody has to have some advice...
Old Mar 14, 2008 | 12:21 AM
2000Hawk's Avatar
If your getting a custom cam from Patrick, just ask him what CR he recommends you run.
-Joel
Old Mar 14, 2008 | 08:44 AM
tylerdj's Avatar
You'll get a lot more responses in the internal engine section.
Old Mar 14, 2008 | 08:07 PM
I have the same post in the internal section and no responces yet...
I know PatrickG can offer advice ont eh compression ratio nbut I am wondering what the best way to go about betting around 11:1 is weather it be milling the heads and thicker gaskets or leaving the heads alone and using thinner gaskets for more "quench"...whatever that is.
Old Mar 15, 2008 | 10:57 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well if you have it over there as well no need for it here too.
