LS 1 starter Wiring Solution for A body Ignition
Old Mar 15, 2008 | 10:27 AM
clm69z28's Avatar
Default LS 1 starter Wiring Solution for A body Ignition
I was told that there may be an issue of the ls two post starter vs. the Gen II three post starter and the need for some additional wiring to make the key and starter compatible. I have not come across that anywhere so far, do you know if this is an issue? BTW, the ECU and wiring harness are Howell components.
