Actual Head Size?!?!?!!?
Old Mar 15, 2008 | 01:44 PM
JASON11WS6's Avatar
Exclamation Actual Head Size?!?!?!!?
I just bought a set up super comp Hooker 1 7/8 headers used off someone here on this site. On a hunch I wanted to make sure they were 1 7/8 and not 1 3/4! They measured out the 1 3/4. Now before I lose my cool and go off on this guy and try to get my money back, I want to make sure they measure straight up. I know lumber always measures smaller then they say. Like 2x4 is actually 1 3/4 by 3 3/4 or whatever it is. So are 1 7/8 supposed to measure exactly that or do they technically run smaller? Also, just to make sure they measure in the inner diameter right? Thanks in advance.
Old Mar 15, 2008 | 03:30 PM
ss1's Avatar
ss1
Nope, headers and all steel tubing as far as I know are measured by the OD of the pipe. If you have ~1-3/4" ID most likely its a 1-7/8" 16ga primary tube.
Old Mar 15, 2008 | 07:48 PM
BlackDuk98's Avatar
I have Hooker Super Comps also. The part number should be stamped on the flange, then you can just match up the #
Old Mar 16, 2008 | 12:20 PM
JASON11WS6's Avatar
Thanks guys, I was getting nervous for a minute there.
