Problem with AIR block off plate ... Need help
Old Mar 15, 2008 | 04:41 PM
ballhawkdawk's Avatar
Default Problem with AIR block off plate ... Need help
I'm taking off my AIR and EGR today and the right block-off plate is loose after I ratchet it down, so I take the bolts out and try to ratchet them down again. Still loose, ratchet a bit more and the head comes off of one of the bolts. Uh oh!
Any suggestions?
Old Mar 15, 2008 | 04:57 PM
MikeG's Avatar
You could either drill it out or try to grab the bolt with some vise grips or something and walk it out.
Old Mar 15, 2008 | 05:09 PM
WhiteStripes's Avatar
Easy out? Those have worked for me in the past when I snapped a rocker arm bolt off in the head. talk about a scary situation. Also try to re-use the gasket that was on that spot to begin with, or use some high heat RTV sealant to make sure you don't have any leaks.
Old Mar 15, 2008 | 05:54 PM
Where can I get easy out? The only place I found was online.
Old Mar 15, 2008 | 06:01 PM
thebart455's Avatar
u should be able to buy a easy out at a hardware store oh and i reused my stock gaskets when i put my plates on
Old Mar 16, 2008 | 03:47 PM
sevenstarsfall's Avatar
Sears should have all the tools you need for this and is usually located pretty close to eveyone.
