Hooker long tube install
Old Jul 23, 2003 | 09:28 AM
redsscamaroboy's Avatar
Default Hooker long tube install
I am going to finally install my headers(embaressed to admit they have been sitting for over 2 monthes in the house).
Question is do i need o2 sensor harness extenders or will the factory o2 wiring be ok on the longtubes?
Anything i need to install them ? i have a 00 and they came off a 01,i will be deleting the a.i.r. system and also removing the egr and replacing the plug wires with new a MSD set.
Any help is greatly appreciated.
Dave
Old Jul 23, 2003 | 10:14 AM
TEX2KZ28's Avatar
Default Re: Hooker long tube install
Yes you will need the o2 extensions. Mine came with them. You will need 02 simulators for the after cat sensors. Use you AIR gaskets and make your own block off plates from sheet metal. It's easy. I just installed mine last week. The work area is a little tight but they fit great.
Old Jul 23, 2003 | 11:18 PM
Thanks for the info. I was hoping to get away with not using them ,i have everything else except them. Headers came with block off plates on them.
