fast 92 and blue max throttle body
Old Mar 24, 2008 | 05:59 PM
TLewis4095's Avatar
Rons got another line of billet TB's that are known to NOT have the sticking issues.
Old Apr 17, 2008 | 09:01 AM
ls1toy's Avatar
any update? I'm just curious because I just bought my fast92+bluemaxx today from Ron. If your still having the problem then I'm going to change my order. Thanks,
Old May 15, 2008 | 07:31 AM
99 Pewter TA's Avatar
I got mine installed last week and have the same issues with the TB sticking. I am going let it break in and adjust the TB stop screw. In traffic I just hit the gas and then the brake and it stops the problem, but idling at 1300rpms is getting tiring some.
Old May 15, 2008 | 07:49 AM
Pesticide's Avatar
Two words Nick Williams.
You should be able to return it. IMO you should not have to modify something that is brand new. I understand parts like headers and chassis pieces sometimes need a little finessing but a throttle body should be smooth and not stick....after all thats its job.
Old May 15, 2008 | 09:08 AM
I found this:
Does it hang open if the the throttle cable is disconnected ? The reason I'm asking is because the little hole on the throttle body where the round anchor on the end of the throttle cable fits into might be a tad too tight and causing it to stick . It needs to be able to rotate freely . Fast throttle bodies have a reputation for doing the same thing and that seems to be the culprit . My Fast throttle body did this and all I did was take a drill bit that was the next size up from the hole and drill it out and that stopped it from sticking .
Old May 15, 2008 | 02:17 PM
I am just going to ask Ron to do an exchange for a Nick Williams.
Old Jun 4, 2008 | 01:00 PM
Gh0st's Avatar
Jedi Master
How did this go? Mine has always stuck but now it's sticking a lot more with this real bad heat.
