car starting problems...
correct me if im wrong. get a resistance reading on the keys pellet then unplug the lock cylinder and put a resistor with the same resistance as key into the connection? wouldn't it have a wrong reading on the key if the car wont recognize it anyway?
If the key is giving you a false ohm value and you put a bypass
resister of the same ohm reading on the connectors, then its not going
to work. GM has several different ohm values for our keys. I had to get
an extra key with a 10K reading if I remember correctly.
On the flip side, if the key is reading one of GM's specified ohm values
than maybe the key isn't making good contact. If that's the case a bypass
resistor would be a good approach. If you are putting the right ohm value
and the car still doesn't start, it would lead one to believe that maybe
the ECU isn't reading the ohm values correctly.
