5.3 head question
Old Mar 31, 2008 | 07:14 PM
scites's Avatar
Default 5.3 head question
i just picked up a nice set of ported 5.3 heads with 2.02in and 1.57ex valves PRC 650 lift,titanium retainers..but they are milled.030, here is my question i have a comp cam 232 236 duration 598lift on a 112lsa..will i have to get my pistons fly cut or will it work..around what will my compression ratio be? and i was told that i would still use the 7.4in push rods..someone help me out..thanks
stock ls1 bottom end
Old Apr 3, 2008 | 10:41 PM
scites's Avatar
no one has a clue
Old Apr 3, 2008 | 10:57 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Do it the right way and check the PTV clearance and get a pushrod length checker
Old Apr 3, 2008 | 11:06 PM
N4cer's Avatar
You can have your combustion chambers CC'd to calculate your compression.
Then measure when you go to install them.
Old Apr 4, 2008 | 12:13 AM
2002_Z28_Six_Speed's Avatar
What is the casting number?
I have heard the later model 5,3 heads use a ,6mm longer pushrod. Don't take that as 100% true just yet.
Old Apr 4, 2008 | 12:32 AM
MrElectric03's Avatar
Really nobody on here can answer those questions. Before you install them you will need to cc the chambers and use a compression calculator(try a search) to determine that. You want to think about both static and dynamic compressions.
As for the pushrods....as stated before you have to get a pushrod length tool. If you look through the stickys and do some searched there is a really good write up for it.
