Difference between 98 Camaro and 98 Trans Am wiring harnesses??
Old Apr 1, 2008 | 11:42 PM
Mike96z's Avatar
Default Difference between 98 Camaro and 98 Trans Am wiring harnesses??
Alright, i have a 96 camaro with a 98 LS1 engine, trying to convert to LS1 camaro interior, fuel tank, body harness, under engine harness etc. Was wondering besides the headlight wiring and fuses etc for the trans am headlights and motors, is there any difference in the other stuff, like tail light harness, dash harness and interior stuff. I know the fuel tank and lines should be the same as well as abs but as far as using a 98 t/a body wiring harness with a 98 camaro dash, will this work? anyone? thanks for any input, need to know this as soon as possible. I already have an engine harness so no need to compare those.
Old Apr 3, 2008 | 09:59 PM
silverLSWON's Avatar
a trans am dash/interior harness will work but i think it has more/extra connectors for the monsoon speakers, camaro has 6, i think the ta's have 8. the door/rearview mirrior harness is different from trans am to the camaro. the connecters that go into the speakers are different, also might want to check the rear speaker connecters to. when i swaped everything into my 96 camaro, i had to widen the hole in the floor whare the body harness connects to the rear abs/fuel pump wiring. the camaro front end harness is different than the t/a but am uncertain if they can be used in one another
