ASP Overdrive Alternator Pulley
Old Jul 28, 2003 | 04:11 PM
Scalpel's Avatar
Default ASP Overdrive Alternator Pulley
How much does this boost amperage output of the alternator if you have an ASP underdrive pulley? Thanks.
Old Jul 29, 2003 | 08:31 PM
Scalpel's Avatar
Default Re: ASP Overdrive Alternator Pulley
ttt
Old Jul 30, 2003 | 09:43 AM
SSCamaro99_3's Avatar
I had some issues with the alternator pulley. It was too tall and walked the belt off inside of 50 miles.
Old Jul 30, 2003 | 11:50 AM
trackbird's Avatar
Levi,
They attempt to return the alternator to it's original rpm to eliminate any loss of charging performance. If the belt stays on, it seems like a good idea for those who need additional amperage. Why are you looking at the overdrive pulley? Charging problems? Just wondered...
Old Jul 30, 2003 | 12:02 PM
Scalpel's Avatar
Kevin, I'm dropping a big stereo in it, but I have a dual battery setup going in as well and was looking for alternatives other than putting the stock UDP back on or a bigger alternator.
