True Duals Question
Old Apr 3, 2008 | 10:47 PM
00cls1camaross's Avatar
Default True Duals Question
on the driver's side header, how did you make a 3 inch pipe fit? Part of the floor pan is protruding out, what did you do?!?!?!?!?!?!?!?!?!?!?!?!?!
Old Apr 4, 2008 | 02:49 AM
Y2K SS's Avatar
My old one placed the mufflers under the passenger seat next to the driveshaft. Actually had to pound up the pan under the passenger seat for it to fit.
Old Apr 4, 2008 | 06:36 AM
teke184's Avatar
went under it....with poly motor mounts you can get it reaal close without hitting under load.
you could also heat up that are of the pipe and make some small indentations. would have no affect on flow, but could give you 1/4" more clearance or more.
i ended up angling the front of the exhaust pipe down right off the collector, then going back...i think i have a picture
this isn't a great picture, but you can see how it angles down immediately off the collector
Old Apr 4, 2008 | 11:40 AM
DarkhorSe_SS's Avatar
get it done by a shop for the piping...mine looks nice and not at all hammered or dented.
Old Apr 4, 2008 | 07:28 PM
01ssreda4's Avatar
also follow the indention in the floor where the factory y pipe goes, that gets you the highest path on that side. mine is angled down after the driver header to clear.
