poly motor mount lube?
Old Apr 10, 2008 | 02:53 PM
Omec's Avatar
Default poly motor mount lube?
was woundering if any one uses poly lube or just put em in dry.
Old Apr 10, 2008 | 03:12 PM
bczee's Avatar
Which motor mount are you referring too ?
If you using Vette with a round donut. yes.. use the lub.
If it is the SBC or other simular type of motor mounts, I would not think that there is any servicable area that has contact that you would need to apply Lub too?...
You can lub up the through bolt.. but it would only be in a small area of contact with metal to metal, not the poly..
So.. which type of motor mount are you referring too?
Old Apr 10, 2008 | 03:50 PM
Omec's Avatar
um the ls1 motor mounts. they are in clam shell cases. i wasnt sure if i should lube them before install. didnt know if anyone had problems w/ them squeezing out.
Old Apr 10, 2008 | 03:59 PM
Viper's Avatar
Nope, put them in and forget about it. That's it!
Old Apr 10, 2008 | 04:33 PM
Omec's Avatar
sweet thanks man.
Old Apr 10, 2008 | 06:27 PM
RippinZ121's Avatar
X2. Thats what i did.
Old Apr 10, 2008 | 07:02 PM
kirby's hawk's Avatar
X3 I did mine without lube and havent heard a peep.
Old Apr 10, 2008 | 08:35 PM
CAMAROZ28AQUINO's Avatar
i just dropped em in no lube
Old Apr 10, 2008 | 09:07 PM
adidazman15's Avatar
stick it in dry brother
