99 v6 camaro
Old Apr 12, 2008 | 07:57 AM
venom99's Avatar
Default 99 v6 camaro
does any one know if they make a conversion harness for a 3.8 to a ls1 i heard they do but was just wondering if any one can help me out on this or do i need to buy the pain less haress to swap motors
Old Apr 14, 2008 | 04:19 PM
Bird_Of_Prey's Avatar
Everyone that did the swap that I know of used an LS1 harness and PCM.
Old Apr 17, 2008 | 09:49 PM
venom99's Avatar
how hard is it to swap all of the electrical over will it just plug in or should i go with a pain less harness
Old Apr 17, 2008 | 10:07 PM
TUFAS4U's Avatar
painless does give you more harness length
Old Apr 17, 2008 | 10:56 PM
1320 killer's Avatar
There is no conversion. if your swapping for a ls1 then just use the ls1 pcm and harness.
Old Apr 17, 2008 | 11:10 PM
venom99's Avatar
is it pretty much plug and play with the stock harness i have never messed with a ls based motor or any f body's so was just curious on what has to be hooked up to to fuse box on the harness and so on
