How much More HP is Fast Intake VS LS6
Old Apr 12, 2008 | 11:18 AM
corvet786c's Avatar
Default How much More HP is Fast Intake VS LS6
Just wanted to know if there is proof or dyno tested of either Thanks.
Old Apr 12, 2008 | 11:21 AM
Gh0st's Avatar
Jedi Master
I wish I knew. I only gained 50hp/40tq by adding LS6 CNC Ported heads and a ported Fast92. Unfortunately I did both at the same time so I can't tell what made what.
Old Apr 12, 2008 | 11:25 AM
ShevrolayZ28's Avatar
Try a search in the dyno section.
Old Apr 12, 2008 | 12:06 PM
TLewis4095's Avatar
None if it is a stock motor, but w/heads & big cam you can see 15 or more depending on the combo.
Old Apr 12, 2008 | 12:42 PM
Detoxx03's Avatar
I gained 28rwhp and 20rwtq by switching from a ls6 to fast92mm on the initial dyno then went back for a dyno day and gained 4 more rwhp. I am cam only btw
Old Apr 12, 2008 | 02:48 PM
68birdls1's Avatar
You say only as if 50 hp and 40tq is not alot or something.
