kooks ory NEED HELP ASAP!
Old Apr 12, 2008 | 01:46 PM
RAIDER's Avatar
Default kooks ory NEED HELP ASAP!
Well I got everything in but the last pipe going from the drivers side header to the other part of the y. My question is do the two Ypipe pieces slip into to each other or does a clamp just hold them up. Because it looks like they slide in but we cant get them to fit. any help would be appreciated
michael
Old Apr 12, 2008 | 02:14 PM
sixvi6-camaro's Avatar
They should slide into each other but its a snug fit.
Old Apr 12, 2008 | 07:42 PM
bichin95redta's Avatar
Been there, done that, too many times. I've lost count of the number of times I've had the exhaust in & out of my car. The last time I did battle with it, I got fed up, took the exact section of Y-pipe you're talking about to my chop saw, and just kept slicing thin rings off of it until I got a good fit. I should have done this a loooooooong time ago. That section of Y-pipe was just too long. I had the exact same set-up on my previous '02 WS6, and Stevie Wonder could have installed it in about an hour.......every pipe fit perfectly.....go figure.
