what type of sheet metal to use????
Old Jul 30, 2003 | 04:37 PM
ninobrn99's Avatar
Default what type of sheet metal to use????
I'm going to attempt to make my own ssra. What should I use that will not cause any overheating issues and lightweight???? all time and help is appreciated!!!!
Old Jul 30, 2003 | 04:59 PM
trackbird's Avatar
Default Re: what type of sheet metal to use????
Aluminum, probably a minimum of 40 thousandths thick. Just my thoughts.
Old Jul 31, 2003 | 02:16 PM
Cal's Avatar
Cal
You could use about any material that you are able to work with, it's just an air duct. 20 gage aluminum or stainless steel sheet metal would be my choice. You will need a sheet metal brake and a spot welder, or you could use rivets or small bolts and nuts; just be sure to use loctite. MIG welder on low heat is another option.
